I defined core walls onced I introduced the walls, but I can not see the results of core walls in the building results diagram dialog box.
What should I do to see them?
Solved by Rafal.Gaweda. Go to Solution.
Thank you,
I defined floors and everything works well.
I had I little bit of trouble with the floor definition because I had to manually assign every element to a floor. Is there a way to assign to a floor a list of specified elements?
