Is there a way to copy structural axis across projects? I need to copy structural axis to a project with different settings (codes, materials etc.)
When I export axis from Revit to RSA, it is opened in a new file, how do I copy these to an existing robot file (the one with deifferent settings) which has newer been klinked with revit before? quick answer would be appreciated. Thank you.
Solved by Rafal.Gaweda. Go to Solution.
Try this way:
- save job preferences as default ones on the file with "new" codes
- load file with axes
- delete everything except Structural Axes
- load default preferences (afterwars should be the same as in file with "new" codes)
- start second robot, load file with "new" codes, CTRL+A, CTRL+C
- swithc to previous Robot (with axes), CTRL+V
