I've found very annoying bug, when tried to copy from the Detailed results tab to Excel.
Please see this short video.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Solved by Romanich. Go to Solution.
I don't have such issue in my Excel. Check what format you have set for lines 13 and 14.
Anybody else having similar issue?
Hi Artur,
It is not depend from selected lines.
I found solution - dot should be separator of integer and decimal part. For Russian settings by default is comma.
Roman Zhelezniak
