Discussion Groups
Robot Structural Analysis
andrea.pontiggia
Accepted Solution
Coordinates of the nodes
243 Views, 13 Replies
01-24-2013 01:18 AM
In a model I have the coordinates of the nodes with values of type X  = 20.58888833  and Y=15.56559999.
The model is imported from Revit, why Revit fails to draw with a degree of accuracy of less? For example, X = 20.60 and Y = 15.55
Second question, in the same robot model if I run the automatic correction with precision = 0.01, after the model has the same coordinates.
You can correct the model automatically?
thanks
Andrea
Please use plain text.
Product Support
Rafal.Gaweda
Re: Coordinates of the nodes
01-24-2013 01:28 AM in reply to: andrea.pontiggia
Use this utility:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Rounding-up-coordinates-API/m-p/3430533/high...
Rafal Gaweda
Product Support
Rafal.Gaweda
01-24-2013 01:33 AM in reply to: andrea.pontiggia
Use correction
or Generate Model with correct precision
Rafal Gaweda
andrea.pontiggia
01-24-2013 01:50 AM in reply to: Rafal.Gaweda
The problem now is that the coating does not transmit the load. How do I fix this? thanks
Andrea
Product Support
Rafal.Gaweda
01-24-2013 01:56 AM in reply to: andrea.pontiggia
Send us Revit model to check
Rafal Gaweda
andrea.pontiggia
01-24-2013 02:17 AM in reply to: Rafal.Gaweda
This is the Revit file: http://we.tl/7ylJ7MuqIN
Andrea
Product Support
Rafal.Gaweda
01-24-2013 03:43 AM in reply to: andrea.pontiggia
Taka e look below at RST analytical model errors
Robot file with corrected geometry attached (my understanding how this should be done).anaerros.jpg
Rafal Gaweda
Product Support
Rafal.Gaweda
01-24-2013 07:10 AM in reply to: Rafal.Gaweda
RST model correction
1. To unjoing wrongly connected columns from walls (marked on right hand sied on screen capture in previous post)
2. Walls can be corrected this way:
3. Beams
4 Braces : http://screencast.com/t/Sl1NhtJm
Corrected model  http://www.4shared.com/file/HGHEme1r/Edificio_21a_v031.html
Rafal Gaweda
andrea.pontiggia
01-24-2013 07:25 AM in reply to: Rafal.Gaweda
Thank you very much!!!!!
The video  to correct braces me to a feature of Revit did not know.
Andrea
Product Support
Rafal.Gaweda
01-24-2013 07:28 AM in reply to: andrea.pontiggia
You may also drag this nodes but sometimes Align works faster and better.
Rafal Gaweda
