Discussion Groups
Robot Structural Analysis
Active Member
Robot12
Coordinate Systems used in Autodesk Robot Structural Analysis
290 Views, 7 Replies
07-08-2012 07:47 AM
What is the difference between the local bar coordinate system and the global bar coordinate system ?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Coordinate Systems used in Autodesk Robot Structural Analysis
07-09-2012 12:07 AM in reply to: Robot12
The local is determined by the position of the bar in the 3D space (X along a bar) and its rotation about its own X axis (Y and Z).
Artur Kosakowski
Active Member
Robot12
07-09-2012 07:29 AM in reply to: Artur.Kosakowski
I am analyzing a building using a 3D frame. Would the displacement experienced by each node used in the frame be in the local coordinate system or in the global coordinate system ?
Product Support
Artur.Kosakowski
07-09-2012 11:38 PM in reply to: Robot12
In the global coordinate system but deflections of bars in the local ones.
Artur Kosakowski
Active Member
Robot12
07-10-2012 07:15 AM in reply to: Artur.Kosakowski
In your answer you mention bars. Would the displacement of the nodes used in the 3D frame be in the global coordinate system and the deflection of the nodes used in the frame be in the local coordinate system ?
Product Support
Artur.Kosakowski
07-10-2012 07:39 AM in reply to: Robot12
The deflection does not refer to a node; you can only see a displacement of a node regardless of an object it belongs to.
See also http://forums.autodesk.com/t5/Autodesk-Robot-Structural/RESULTS-DISPLACEMENT-vs-DEFLECTION-Definitio...
Artur Kosakowski
Active Member
Robot12
07-12-2012 02:23 AM in reply to: Artur.Kosakowski
Would the values of RX, RY and RZ that appear in the displacement results table be in the global coordinate system ?
Product Support
Artur.Kosakowski
07-12-2012 02:58 AM in reply to: Robot12
Correct.
Artur Kosakowski
