Coordinate Systems used in Autodesk Robot Structural Analysis
7 REPLIES 7
Message 1 of 8
682 Views, 7 Replies
What is the difference between the local bar coordinate system and the global bar coordinate system ?
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
The local is determined by the position of the bar in the 3D space (X along a bar) and its rotation about its own X axis (Y and Z).
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 8
in reply to: Artur.Kosakowski
I am analyzing a building using a 3D frame. Would the displacement experienced by each node used in the frame be in the local coordinate system or in the global coordinate system ?
Message 4 of 8
Artur.Kosakowski
In the global coordinate system but deflections of bars in the local ones.
Artur Kosakowski
Message 5 of 8
In your answer you mention bars. Would the displacement of the nodes used in the 3D frame be in the global coordinate system and the deflection of the nodes used in the frame be in the local coordinate system ?
Message 6 of 8
Artur.Kosakowski
The deflection does not refer to a node; you can only see a displacement of a node regardless of an object it belongs to.
See also http://forums.autodesk.com/t5/Autodesk-Robot-Structural/RESULTS-DISPLACEMENT-vs-DEFLECTION-Definitio...
Artur Kosakowski
Message 7 of 8
Would the values of RX, RY and RZ that appear in the displacement results table be in the global coordinate system ?
Message 8 of 8
Artur.Kosakowski
Correct.
Artur Kosakowski
