Does anyone tried to model in Inventor complicated structures consisiting of thin surfaces (etc) only and somehow export file to use it in Autodesk Robot shell analysis?
I would like to use Robot for calculation, but ofcourse Inventor is so great with modelling thus I would like to compile its power. Please do not refer me to Inventor simulation, I have to use Robot since it fits required path of designing with combinations etc...
Best regards,
EMM !
Solved by bartass6. Go to Solution.
You need to use SURFACE elements in Inventor, then save inventor file as *.SAT file type. In Robot open *.sat file, but remember to have solid modeler switched on ( Preferences->View Parameters). Now you have objects called "geometrcal objects " in Robot window. You have to now change them to PANEL elements. Go to PANEL icon, choose your "geometrical objects" ans assign them in Object list in PANEL window. It is now assigned as panel, but you need to go back to Preferences->View Parameters and turn off Solid Modeler to assign mesh in Robot as for 2D objects and not for 3D(solid) objects. Thats it! You will see that your "geometrcal objects " will disapear and only panels will remain.
