Hi
I have a fairly complicated 3d solid model of a consistant thickness that I would like modelled as a shell element. This will allow me to alter the thickness accorindgly (hopefully) depeneing on the structural performance.
Is there anyway to do this? The 3d solid geometry was imported from a .sat file.
Thanks for your time
OG
Solved by Rafal.Gaweda. Go to Solution.
Not possible.
You have to open already prepared "flat" sat file
