Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Convergence problem CABLE
4 REPLIES 4
DTHepta
198 Views, 4 Replies
I am modeling a structure hanging from cables. I do not understand why the calculation does not converge. If instead of vertical cables I replace they with internal constraints (eg pinned link), the convergence problem disappears.
Thank you for your attention,
Daniele
4 REPLIES 4
Rafal.Gaweda
in reply to: DTHepta
Start with elongation relative -(minus)0.01
Rafal Gaweda
DTHepta
in reply to: Rafal.Gaweda
Thank you,
the calculation converges. Refining the mesh I get a very strange deformation of the cable, which moves upward with downward curvature. It seems to me that the loads are in the correct direction, so you ask you what can be had.
Thank you,
Daniele
DTHepta
I'm sorry,
this is the correct file.
Rafal.Gaweda
It means that the cable curves you have drawn are not the optimal ones and you got kind of stifening effect.
Try \ start from elongation = 0 for cables 78to87
Rafal Gaweda
