Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Continuous footings combinations.
2 REPLIES 2
MARIOS75
380 Views, 2 Replies
Hi all,
is it posible to include manual combinations into  continuous footing analysis?
No matter what i've tried, robot only includes simple cases or combinations that have been generated automaticaly.
Thank you.
2 REPLIES 2
Rafal.Gaweda
in reply to: MARIOS75
Hi
If you import such footing from model it should be possible to select either simple cases or combinations
Rafal Gaweda
MARIOS75
Thanks Rafal,
i'm attaching some screenshots.
I think there is a bug.
9 out of 10 times robot won't accept the manual combination.
In case that accepts it this will cause problems to  the flange bending moments diagram.
