Hi all,
is it posible to include manual combinations into continuous footing analysis?
No matter what i've tried, robot only includes simple cases or combinations that have been generated automaticaly.
Thank you.
Hi
If you import such footing from model it should be possible to select either simple cases or combinations
Thanks Rafal,
i'm attaching some screenshots.
I think there is a bug.
9 out of 10 times robot won't accept the manual combination.
In case that accepts it this will cause problems to the flange bending moments diagram.
