I have a continuous beam that have a support on a concrete wall. Is there some simple way to not transfer moments into the concrete wall? I have tried the pinned linear release but that didn't work.
Solved by Artur.Kosakowski. Go to Solution.
1. Freeze meshes
2. Define compatible nodes in such a way that one of the pair of the nodes 'belongs' to the wall and the other to all bars.
Mind that if you re-mesh the panel you will need to re-define the compatible nodes.
