how do i model a continouis beam with a roller support at the mid span. i need the beam to be continous.
also how do i model a joint to have a semi rigid/pinned support. with a different stiffness.
thanks
Solved by Artur.Kosakowski. Go to Solution.
Solved by GordonSharp1992. Go to Solution.
floor loading
i am lloking to apply a udl on the beam located on the first member . i am looking to mirror furniture loading and load of the floor beams. the total load of the furniture is around 300kg but spread all over the floor . how would i estimate the udl for one beam ?! not sure how to do this ?
