Discussion Groups
Robot Structural Analysis
Active Contributor
GordonSharp1992
Continuous Beam design
672 Views, 40 Replies
02-14-2014 02:31 AM
how do i model a continouis beam with a roller support at the mid span. i need the beam to be continous.
also how do i model a joint to have a semi rigid/pinned support. with a different stiffness.
thanks
Please use plain text.
Product Support
Artur.Kosakowski
Re: Continuous Beam design
02-14-2014 03:15 AM in reply to: GordonSharp1992
It should be enough to  define a node with the UZ blocked at the point where the support is located.
Use the elastic (tab) support definition
Artur Kosakowski
Active Contributor
GordonSharp1992
02-14-2014 03:47 AM in reply to: Artur.Kosakowski
i get insability how can i change this
in all directions how do i change this
do i leave Ux and Ry unticked ?
Product Support
Artur.Kosakowski
02-14-2014 03:52 AM in reply to: GordonSharp1992
Attach the model please.
Artur Kosakowski
Active Contributor
GordonSharp1992
02-14-2014 03:55 AM in reply to: Artur.Kosakowski
heres the model
i need to model semi rigid/pinned supoports at node 3 and 4
and a contiouous beam from 1-3
with a roller at the point show
Product Support
Artur.Kosakowski
02-14-2014 04:00 AM in reply to: GordonSharp1992
I'm not sure if I understand this description correctly. Could you make a sketch of the model and indicate which d.o.fs you want to block, have elastic, release in particular nodes please?
Artur Kosakowski
Active Contributor
GordonSharp1992
02-14-2014 04:15 AM in reply to: Artur.Kosakowski
the structure is a cantilever extention. from nodes 1 to node 3 is a continuous beam with a roller support at location node 2. i want to make it cantilever but i am struggling !
i also want to make node 3 and 4 semi rigid/fixed .
i have attached the poster for my structural project if this helps
Active Contributor
GordonSharp1992
02-14-2014 04:17 AM in reply to: GordonSharp1992
Product Support
Artur.Kosakowski
02-14-2014 06:29 AM in reply to: GordonSharp1992
The modified model  as on the picture you attached
Artur Kosakowski
Product Support
Artur.Kosakowski
02-14-2014 06:52 AM in reply to: GordonSharp1992
 And the model that (I hope) matches this description
Artur Kosakowski
