I'm trying to model a truss structure with phases.
I want to be able to do two kind of things
1) check every configuration and be able to add, remove, bars, change support type between phases ->ok
2) I want to create combination that contains loads cases from different phases (this in order to into account the history of loading during the construction). Typical example is removing a support after pouring concrete on a metal sheet deck or phased construction of a truss the heigh of which is several floor.
I tried to do that but it seems that the results can be displayed only for bars active in all the phases .... in some example I didn't manage to display any results ... another strange thing : result status is frozen to "non actuel"...
One simple example attached.
Solved by Pawel.Pulak. Go to Solution.
Solved by t.sautierr. Go to Solution.
Should have seen before asking ! :
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Collecting-phases/td-p/3505898
http://screencast.com/t/spinoktq
TS
Yes, it is the best to start by searching the existing posts:)
As concerns the status of results "non actuel" (or "out of date") in case of phase structures it will change into "available" after collecting phases.
