connections welding
31 REPLIES 31
Message 1 of 32
1671 Views, 31 Replies
connections welding
Hi
I have my forces on the member
Max : Fx = 1.67 kN; Fy =3.43 kN ; Fz = 1.3 kN; Mx = 0.15 kN.m; My = 0.94 kN.m; Mz = 0.74 kN.m
Min : Fx = -2.34 kN; Fy =-3.5 kN ; Fz = -3.61 kN; Mx = -0.11 kN.m; My = -1.04 kN.m; Mz = -1.11 kN.m
And I want to know where I can use this forces on my assembly ?? Forces in bars but which forces i choose ?
You can see the file attached.
See section Steel design : Connections
31 REPLIES 31
Message 21 of 32
I can consider 4 welds with Eurocode ? or it.s impossible ?
And with Robot, I can't chosse an option like 2 welds or 4 welds ?
In Eurocode3 : section 4.1, file attached, there is no 0.9 factor, why in Robot there is 0.9 ?
Message 22 of 32
Artur.Kosakowski
If you mean for hand calculations than my assumption would be that you can yet it is not recommended.
Robot always follows the recommendation I indicated in my previous post.
My understanding is that it is what 2005 release says however if I remember correctly 0.9 wasn't in the previous version of EC3.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 23 of 32
in reply to: Artur.Kosakowski
Just to be sure, in Autodesk Robot : Connections.
The ad = 5 [mm] Thickness of welds of diagonals and posts is equal a (see the pic)
Or ad is equal s ?
Thank you.
Message 24 of 32
Artur.Kosakowski
Artur Kosakowski
Message 25 of 32
Artur.Kosakowski
Your value is correct. We need to investigate the calculations of stress caused by bending. Thank you for notifying us about this situation.
Corrected in SP4 for Robot 2015.
Artur Kosakowski
Message 26 of 32
where can i find SP4 for Robot 2015 ?
or give me readme file
Message 27 of 32
Artur.Kosakowski
At the some location in couple of days.
Artur Kosakowski
Message 28 of 32
sorry for this question
what the purpose of sp4 ?
Robot 2016 will release on 25 April
Message 29 of 32
Will you add AISC connections in Robot 2016 ?
Message 30 of 32
Artur.Kosakowski
To make Robot 2015 be even better Smiley Happy
Artur Kosakowski
Message 31 of 32
Message 32 of 32
Artur.Kosakowski
You can export RSA model or selected elements to Advance Steel > create connection(s) > verify them for forces imported from Robot according to US code.
Artur Kosakowski
