Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Connection steel beam-column Robot
2 REPLIES 2
487 Views, 2 Replies
I want to create a connection between a continuous beam (IPE220) and a column(IPE270) welded in the middle of the beam.
The problem is that Robot creates the connection using the column continuous in stead of the beam.
How can I change it, to have the beam continuous and not the column?
Thank you in advance!
2 REPLIES 2
Artur.Kosakowski
Such connection type is not supported. It could have been created only if the vertical bar was rotated by 90 deg comparing to its current orientation.
Artur Kosakowski
in reply to: Artur.Kosakowski
Hello!
Thanks for your message!
It is a pity that Robot can't do this type of connection.
