I'm facing an issue with the following setup:
node 1: 0,0 (support type: fixed)
node 2: 0,2000
node 3: 2000,2000
bar 1: column from node 1 to node 2
bar 2: bracing from node 1 to node 3
the rest of the construction is not meaningful for this issue.
After doing the FEM analysis I want do to a connection column base design. When doing this design the connection is designed for the bar forces from bar 1 (column) only. The forces from bar 2 (bracing), which, in practice, need to be guided trhough the base plate of the column to the concrete, are not included in this calculation.
This seems logical as both bar 1 and bar 2 end directly in a fixed support and thus the forces from bar 2 will never work on bar 1 and thus not on the connection.
I can solve this by adding an extra node 4: 10,0 and let bar 2 going from node 4 to node 3, so that the force from the bracing will affect bar 1 (column). However, my design has centerlines running exactly to node 1.
So if I make my centerline model correct, the connection forces are wrong. If I make the model such that the connection forces are correct, the centerlines are not correct and I need extra nodes.
What is the best solution for such an issue?
Secondly, I have modelled the connections in the beginning of the project. After that I ran the analysis and the connection calculations. Then an update on forces was done, so a recalculation was needed. I ran the analysis and re-ran the connections. I expected Robot to auto-update the forces in the connections calculations after the analysis was re-ran. Apperently this doesn't happen and I have to update the connections and then re-run them to get correct forces in the calculations. Is this how it should be done?
Solved by Artur.Kosakowski. Go to Solution.
It's time to upgrade to v.2012
You can update the forces by pressing the indicated button:
