Hello. Please help me if you have any solutions.
I have two connecting walls. One of then is stenght wall, another is cylinder surface (from library structure). And when trying to create a mesh between them in order to this walls work together, i have no luck. I tried by differrent meshing methods. You can see this in attached files.
Thank you in advance.
1. I think this is a different model but nevermind
2. Kinematic links off
3. No regular mesh
4. Model is not well made = inaccurate
Panels 2 20 24 78 connected inaccurately:
slab not connected with walls
different number of division of "cylinder" wall and circular slb egdes
radial walls not connected to "cylinder walls"
(I suggest to model "cylinder" walls from flat panels to control connection between, walls, slabs in much easier way)
Thanks a lot for support!
Of course i will do it more accurate. Principal solutions for this are items 2,3. Thanks again.
Sorry for inconvinience. It's interesting, but sometimes it works somtimes not. In my scheme it works only in new window. But for attached panels i can't do it at all. Can you sent me back this file with all the sttings that you aplly? I will appreciate it.
Split \ remodel cylinder walls as shown above
Example model attached
I did not split it. I defined new panels basing on corner nodes \ characterisctic points of original wall.
