Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Connecting Rigid Link between Cable and Plate
9 REPLIES 9
Message 1 of 10
kranic24
758 Views, 9 Replies
Can anyone help me determine what I'm doing wrong here? I want to attach a steel plate to a cable. The cable is continuous from bottom to top however I modeled with nodes in the span in order to apply some rigid links that will be holding up the steel plate. When you have cable-to-cable nodes do i need to add a "connection"? I only have a uniform windload applied in addition to pretension and some dead load (no loads in y direction).
9 REPLIES 9
Message 2 of 10
Rafal.Gaweda
in reply to: kranic24
Pdelta calculation must be run.
What else - send us screen capture or model.
Check also:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Cable-ROBOT/td-p/3393233
Rafal Gaweda
Message 3 of 10
kranic24
Screen shot attached
Will not let me upload model (.rtd file)
Message 4 of 10
Rafal.Gaweda
zip it before attaching or upload and send link from services www.filemail.com or wetransfer.com
Rafal Gaweda
Message 5 of 10
kranic24
in reply to: Rafal.Gaweda
Message 6 of 10
Rafal.Gaweda
Structure Type should be Frame 3D or Shell.
Ther are only truss bars due to Truss structure type - so they have no rotational dof.
Corrected model attached
Rafal Gaweda
Message 7 of 10
kranic24
Thanks for the assistance Rafal. The model type mistake makes sense, clearly. However I still have not determined the necessary steps to add rotational support to my cable that has been "broken" up into segments. I am not able to get this model to run due to stability issues....help?
Message 8 of 10
kranic24
Anyone know how to connect a rigid link to cable midspan and make it structurally stable? Do i need to somehow use "Compatible Nodes"? Do I need to segment my cable and then add cable releases? Help please.
Message 9 of 10
Rafal.Gaweda
I do not think you have read my posts or document about cables in the thread I mentioned.
Errors in your model:
- wrong supports
- missing pdelta
Rafal Gaweda
Message 10 of 10
Rafal.Gaweda
Connected properly in your model. What about replacing rigid bars by rigid links?
Yes.
add cable releases?
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-A761540B-9E96-4760-AF04-47E22059B83-241.htm
Rafal Gaweda
