Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
concrete et Analysis
7 REPLIES 7
Message 1 of 8
FabriceMendelski3705
456 Views, 7 Replies
Bonjour j'ai modelisé un batiment sur concrete en suite exporté sur le module Analysis coques, apres calcul, j'obtiens un modele ci dessous (voir Piece jointe) et les calculs sont interrompus avec un message d'ereur élements distors ?
pouvez vous m'aider ?
7 REPLIES 7
Message 2 of 8
File please.
Rafal Gaweda
Message 3 of 8
ci joint lien pour telecharger le fichier :
 http://we.tl/AaPVddeFhl
Message 4 of 8
I am afraid you have to start with correcting model geometry first.
Arc walls, arc slabs edged should have the same discretization and the same numerb and position of characteristic points to get coherent meshes.
Rafal Gaweda
Message 5 of 8
Rafal.Gaweda
in reply to: Rafal.Gaweda
Many continous footings duplicated, example :  166 167 209 237 238 245
Rafal Gaweda
Message 6 of 8
Rafal.Gaweda
continuos footing not defined under walls
Rafal Gaweda
Message 7 of 8
Rafal.Gaweda
Model Generation tolerance should be set 1-2mm not 800 !!
Rafal Gaweda
Message 8 of 8
Rafal.Gaweda
Geometry corrected in attached file
Correct linear releases to get rid of instabilities
Rafal Gaweda
