Hi
I have a composite slab modelled with steel beams. I have offset the beams so the top flanges meet the underside of the composite slab.
Is there a way of exracting the resultant I values when the members are arranged in this way?
Thanks for your time
Oscar
OK great sounds good. I will have a look at Octopus now.
I am less concerned with the deisgn at this point in time, I am more intersted in whether the behaviour of the system is realistic i.e. will deflections and sway reflect the stifness of the composite system? I have modelled the concrete with a large reduction in its modulus to simulate craked concrete (so areas of tension are taken by the steel only).
Will this produce realistic stiffnesses of the composite system and in turn provide realistic deflection outputs?
Oscar
