Discussion Groups
Robot Structural Analysis
New Member
david.byrne2
Composite Concrete Volumetric Structure Design
413 Views, 1 Replies
08-25-2011 04:00 AM
I am relatively new to Robot so I’m still trying to figure out some of the functions. Essentially what I am trying to model is a composite concrete structure using the Volumetric Structure Design tool within Robot. My model consists of 65mm thick Solid precast concrete section with a 385mm thick Solid in-situ element on top (both elements have different properties). I am wondering how best to model the interface between the two concrete elements or if this is at all possible? In theory a failure plane is possible where the two concrete elements are in contact and I was hoping you might be able to explain how best to model this in Robot. I also have a query in relation to modeling reinforcement within 3D Volumetric solids and the best practice for this; is it possible to enter and edit the bond characteristic properties between the steel and concrete? The concrete elements mentioned above will have reinforcement layers placed within them.
Please use plain text.
Product Support
Artur.Kosakowski
Re: Composite Concrete Volumetric Structure Design
08-25-2011 04:50 AM in reply to: david.byrne2
Reading your description I think that what you need are contact elements that are not available in Robot. You may consider using Algor for such types of models.
http://www.algor.com/news_pub/tech_white_papers/surface_contact/default.asp
Artur Kosakowski
