Discussion Groups
Robot Structural Analysis
New Member
helpdesknoauto
Composite Beam Design
592 Views, 3 Replies
02-06-2013 11:27 AM
Can I model a composite steel beam in Robot? I am used to Ram Structural System where it is very easy to define composite beams and stud quantities and perform code checks. It appears to be very difficult to do in Robot. Am I missing something?
Please use plain text.
New Member
helpdesknoauto
Re: Composite Beam Design
02-07-2013 07:42 AM in reply to: helpdesknoauto
Thanks for the response, but I have already seen these threads. They do not answer the question. To confirm the composite capabilities of Robot Structural Analysis, it cannot perform composite design using headed studs on wide flange beams. I would need to manually input the transformed section properties or model the framing as 100% composite. I could not have Robot design a beam that was 50% composite. Please confirm if these statements are correct.
Product Support
Rafal.Gaweda
02-11-2013 12:49 AM in reply to: helpdesknoauto
So we can say it is not possible.
Rafal Gaweda
