Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Composite beam Design in Robot
6 REPLIES 6
gustavo_c_vasconcellos
5019 Views, 6 Replies
I would like to know how can I design a composite beam in Robot.
I tried using Revit Structure:  updating the model and using Composite Design Extension, but, as I designed load (including moving load), and load combination in Robot I am not feeling confortable. I can't see all the loads in Revit.
When I updated the model, I chose the option to transfer results (reactions and internal forces).
Am I missing something? Is there a better way desinging directly in Robot? Or am I doing right?
Gustavo Vasconcellos
6 REPLIES 6
The Revit Extension Composite Steel Beam Design is only available for the AISC Standard Wide Flange shapes, I invite you to read the white paper: http://images.autodesk.com/adsk/files/autodeskrobot_revitstructure_whitepaper_final.pdf
You can also use the Robot Expert tool (according to Eurocode 4):
Or use the Composite Structures' sheet within Robot Extensions- Spreadsheet Calculator:
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Dear Jad,
First of all, I would like to thank you for your reply, but I have some more questions:
- If I am using AISC Standard Wide Flange shapes and model the loads on Robot, do the loads transfer to Revit when I update from Revit?
- I tried the spreadsheet calculator but it appears as a demo version, what should I do?
- Is there any white paper about the spreadsheet calculator, like the one that you send to me about Composite Design?
Hi Gustavo,
There's answers for your questions:
Yes, after importing your structure in Revit Structures, It should work but your structure must fulfill the requirements of this extension, please check its in "About the extension" .
 Please read our post here: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Robot-Extensions-Spreadsheet-Calculator2012/...
No white paper available for SPC, but you can find generally detailed help with some calculations examples for each sheet.
Jad DELLEL
mpcloob
in reply to: jad.dellel
how can i download Robot expert tool for composite beam design ?
jad.dellel
in reply to: mpcloob
Hello Mohammed,
You should have a subscription contract first then, you could download it from subscription.autodesk.com
Jad DELLEL
mpcloob
in the name of  GOD .
I'm a student.I haven't this.
Those who are students do not give Extensions & Plug-ins ? :smileysad::smileysad:
unless the person who is a student? Smiley SadSmiley SadSmiley SadSmiley Sad
we had expected more from Autodesk company Smiley SadSmiley Sad
Autodesk does not respect us unfortunately, but yet we love it Smiley SadSmiley Sad
we don't want extensions for Revit only, we want free extensions for other program that available in Autodesk student website too.
please tell this matter to Autodesk company
