Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Compatible nodes
6 REPLIES 6
1489 Views, 6 Replies
Compatible nodes
I need to change the type of compatibility, I have a lot of nodes compatibles, please see attachement
David
6 REPLIES 6
Please I need some advice how to change the type of nodes compatibility (see my first post)
Artur.Kosakowski
There is no direct way to change the compatible node label but you may try the following steps:
1. Select all compatible nodes you want to change as well as elements attached to them
2. Save this selection as  a substructure (Geometry > Structure > Save Substructure)
3. Delete the selected nodes and objects from the original model and save it under a new name
3. Open the rtd file created in the point 2
4. Rename the compatibility label by double clicking on its name
5. Edit the compatibility definition
6. Save the file
7. Open the file from point 3
8. Insert the file from point 6 (Geometry > Structure > Insert from file)
Artur Kosakowski
Another possibility is using the text file and the Robot command line. See this video
Pawel Pulak
Technical Account Specialist
Rafal.Gaweda
in reply to: Pawel.Pulak
mgaafar
Hi, I tried to add compatible nodes definition via text commands but it nothing happened, I am using RSA 20418.
was this option eliminated in the newer versions of RSA? if yes, how can I manually add about 3000 nodes with its compatibles if I have them in an Excel format (similar to the sample below)
Compatible 32862 UX UY UZ 35831
Compatible 32863 UX UY UZ 35832
Compatible 32864 UX UY UZ 35833
abudayev
could you repost the video. i cannot see it.
