(API) Command VBA Projection Capture of a view
Message 1 of 147
I have a problem with my macro. The command of projection in 3D doesn't work. My view stay in XZ plane.
robapp.Window.Activate
Set mavueRobot = robapp.Project.ViewMngr.CreateView(1)
mavueRobot.Projection = I_VP_3DXYZ
mavueRobot.Visible = True
mavueRobot.Redraw (True)
I want also make a capture of my model with diagram of results. Have you an example of code for it ?
I would like to get for final result the exemple in attachment.
Replies (146)
Message 2 of 147
Artur.Kosakowski
Autodesk Support
Autodesk Support
Seems like one line is missing:
robapp.Project.ViewMngr.Refresh
Artur Kosakowski
Message 3 of 147
Ok but it's not working.
See my attachment
Message 4 of 147
Artur.Kosakowski
Autodesk Support
Autodesk Support
It seems like you missed the attachment.
Artur Kosakowski
Message 5 of 147
Message 6 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
Take a look at attached movie
Rafal Gaweda
Message 7 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
It seems it is related to your computer graphics card (and maybe also 64 bit Robot).
On one of our computers I have the same bahavior.Switching between views (several times), refreshing them manualy etc refreshes view on this viewport.
Rafal Gaweda
Message 8 of 147
The excel file has been created 5 years ago, I don't think this is a problem related to 64 bit Robot.
Message 9 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
No, it was created 09.2001 🙂
Rafal Gaweda
Message 10 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
Update to "your" macro to set map display on view and to make screen capture
Read comments in code below
Public Sub CreeVueRM()
' définition d'une vue
robapp.Interactive = True
robapp.Visible = True
robapp.Project.CalcEngine.Calculate ' calculate model
Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
Set mavueRobot = robapp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use GetView instead
mavueRobot.Selection.Get(I_OT_CASE).FromText ("3") ' selecting case for results display
' displaying map
mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_GLOBAL_DISPLACEMENT_Z
' making screen capture
Dim ScPar As RobotViewScreenCaptureParams
Set ScPar = robapp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
ScPar.Name = "My screen capture"
ScPar.UpdateType = I_SCUT_UPDATED_UPON_PRINTING
mavueRobot.MakeScreenCapture ScPar
robapp.Project.PrintEngine.SaveReportToOrganizer
End Sub
Rafal Gaweda
Message 11 of 147
Ok thanks a lot,
I would like lo have only the screen capture in a file like .jpeg.
In Robot, I can only make a world file and the picture is in a bad quality.
Can we save the capture in a better quality.
I would like to make a macro saving many capture in C:Autodesk.
Is it possible ?
Message 12 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
yes it is possible :
 to create png screen capture with highest reolution
ScPar.UpdateType = I_SCUT_CURRENT_VIEW
ScPar.Resolution = I_VSCR_4096
then you have to export printout to word or save as rtf
or copy directly screen shot to clipboard
ScPar.UpdateType = I_SCUT_COPY_TO_CLIPBOARD
then paste clipboard contents in Word
Rafal Gaweda
Message 13 of 147
Ok but I would like the macro export herself the printout in a folder like C:Autodesk/output.
Message 14 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
robapp.Project.PrintEngine.AddScToReport "My screen capture"
' saving printout \ report to file
robapp.Project.PrintEngine.SaveReportToFile "c:\Autodesk\output\rr.rtf", I_OFF_RTF_JPEG
'or directly opening printout in Word
robapp.Project.PrintEngine.ExternalPreviewReport EPF_MS_OFFICE
Rafal Gaweda
Message 15 of 147
Ok thank you. There is just one command who don't work.
I didn't find it in the ROS manual V9.0.
Is there a mistake or is it no more available ?
Message 16 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
This command is from ARSA 2012, ROS 12
Rafal Gaweda
Message 17 of 147
I have Autodesk Robot Structural Analysis Professional 2011.
Does it work with this software ?
Message 18 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
You already know it does not.
It is implemented in ARSA 2012, Robot Object Modeler 12
Rafal Gaweda
Message 19 of 147
I only find the manual of ROS V9. Do you have the manual of ROS V11 ?
Message 20 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
it should be there:
"C:\Program Files\Common Files\Autodesk Shared\Structural\Help\2011\robotom.pdf"
Rafal Gaweda
