(API) Command VBA Projection Capture of a view
145 REPLIES 145
Message 1 of 146
mateaus
8685 Views, 145 Replies
I have a problem with my macro. The command of projection in 3D doesn't work. My view stay in XZ plane.
robapp.Window.Activate
Set mavueRobot = robapp.Project.ViewMngr.CreateView(1)
mavueRobot.Projection = I_VP_3DXYZ
mavueRobot.Visible = True
mavueRobot.Redraw (True)
I want also make a capture of my model with diagram of results. Have you an example of code for it ?
I would like to get for final result the exemple in attachment.
145 REPLIES 145
Message 81 of 146
mateaus
in reply to: Rafal.Gaweda
Ok but my PC is new and I don't have installed any Robot before. I have only installed RSA 2012.
Message 82 of 146
Rafal.Gaweda
in reply to: mateaus
To register it properly please open Command Prompt as Administrator, registsrer robot, check macro.
If it still does not work please respond to e-mail sent to yout from our system
Rafal Gaweda
Message 83 of 146
mateaus
@Anonymous wrote:
Your EXACT code does not run due to a typo. Even without the typo, and using the rest of the code exactly as you've written, yes, it still crashes.error again.PNG
Even
It's the same for me. Robot crash when ask for better resolution.
I think it's because my computer is not enough speed. When I do some break in the macro it's working. What do I need in the computer ?
I'm in windows seven 64bit with ARSA 2012 and Office 2010
Message 84 of 146
Rafal.Gaweda
Use from time to time DoEvents
or pause code in some places. Pause function dos not exist in VBA so write your own function - example below
This function pauses code for 5 seconds
Sub Wait()
    waitTime = 5
    Start = Timer
    While Timer < Start + waitTime
        DoEvents
    Wend
End Sub
Rafal Gaweda
Message 85 of 146
mateaus
Is that possible to ask Robot : "W
Sub Wait()
    waitTime = 5
    Start = Timer
        DoEvents
    Wend
End Sub
hen the generation of the vue is finished, do something else" ?
Message 86 of 146
Rafal.Gaweda
View generation is one command \ line. After finishing it program steps to another code line.
Rafal Gaweda
Message 87 of 146
mateaus
So how explain that robot crash if I don't put sleeping times :
Sleep 33000  '33 secondes to generate a view of mobile loads
Sub cree_vues_resultats()
If Not Robapp.Visible Then
    Set Robapp = Nothing
    MsgBox "Open Robot", vbOKOnly, "ERROR"
    Exit Sub
End If
fichier_sortie = Range("AE16").Value
Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
Set mavueRobot = Robapp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use GetView instead
mavueRobot.ParamsDisplay.Set 68, False                               'symbole charges ponctuelles
mavueRobot.ParamsDisplay.Set 69, False                               'symbole charges lineaires
mavueRobot.ParamsDisplay.Set 70, False                               'symbole charges surfaciques
mavueRobot.Projection = I_VP_XY_3D
'mavueRobot.Projection = I_VP_3DXYZ
mavueRobot.ParamsDisplay.Set I_VDA_OTHER_RULER, True
Robapp.Project.ViewMngr.Refresh
'faire un zoom
Sheets("Sommaire").Select
transvfactor = Range("I32").Value
transhfactor = Range("I31").Value
zoomfactor = Range("I30").Value
Call zoom_robot
'mavueRobot.Visible = True
'mavueRobot.Redraw (True)
'Robapp.Project.ViewMngr.Refresh
'MsgBox ("Regler la vue dans le modèle")
casprem = Range("N18").Value
casder = Range("N19").Value
prem_cas_roul = Range("N17").Value + 1
For i = casprem To casder
Cas = i
mavueRobot.ParamsFeMap.WithDescription = True
mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SYMBOLS, False
If Range("I21").Value = "Myy +" Then
mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_COMPLEX_REINFORCE_TOP_MYY
sollicitation = "Moments Myy+"
'pour les charges roulantes attention
If i >= prem_cas_roul Then
Cas = prem_cas_roul + (casder - prem_cas_roul + 1) * 3 + ((i - prem_cas_roul) * 2 + 0)
End If
End If
If Range("I21").Value = "Mxx +" Then
mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_COMPLEX_REINFORCE_TOP_MXX
sollicitation = "Moments Mxx+"
End If
End If
If Range("I21").Value = "Myy -" Then
mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_COMPLEX_REINFORCE_BOTTOM_MYY
sollicitation = "Moments Myy-"
Cas = prem_cas_roul + (casder - prem_cas_roul + 1) * 3 + ((i - prem_cas_roul) * 2 + 1)
End If
End If
If Range("I21").Value = "Mxx -" Then
mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_COMPLEX_REINFORCE_BOTTOM_MXX
sollicitation = "Moments Mxx-"
End If
End If
mavueRobot.Selection.Get(I_OT_CASE).FromText (Cas) ' selecting case for results display
ecran_capture = sollicitation & "_ Cas " & i
mavueRobot.Redraw (0)
Call screen_capture
Next i
 'saving printout \ report to file
'robapp.Project.PrintEngine.SaveReportToFile fichier_sortie, I_OFF_RTF_JPEG
Robapp.Project.PrintEngine.SaveReportToFile fichier_sortie, I_OFF_RTF
'or directly opening printout in Word
Robapp.Project.PrintEngine.ExternalPreviewReport EPF_MS_OFFICE
'MsgBox "QUITTER APPLICATION ROBOT"
Sleep 10000
Robapp.Quit I_QO_DISCARD_CHANGES  ' Quitter sans sauvegarde
End Sub
Message 88 of 146
Rafal.Gaweda
send me whole your xls file and any other files required like mobile loads database etc.
Rafal Gaweda
Message 89 of 146
mateaus
Hi
I've got a problem with the scale in the view. It's not the good one I have to do the command normalize in Robot.
Is there a command in VBA API for this ?
Message 90 of 146
Rafal.Gaweda
Unfortunately you can not control scale on force normalization thru API.
Rafal Gaweda
Message 91 of 146
mateaus
I would like to select all "combinaisons" or all of "cas simples" but not both.
I test
mavueRobot.Selection.Get(I_OT_CASE).FromText ("Combinaisons") ' selecting case for results display
but it doesn't work,
Have you got a solution ?
Message 92 of 146
Rafal.Gaweda
Dim SimpleCaseSel As RobotSelection
Dim ManualCombSel As RobotSelection
Set SimpleCaseSel = RobApp.Project.Structure.Selections.CreatePredefined(I_PS_CASE_SIMPLE_CASES)
Set ManualCombSel = RobApp.Project.Structure.Selections.CreatePredefined(I_PS_CASE_COMBINATIONS)
mavueRobot.Selection.Get(I_OT_CASE).FromText (SimpleCaseSel.ToText) ' all simple case for results display
'or
mavueRobot.Selection.Get(I_OT_CASE).FromText (ManualCombSel.ToText) ' all manual combinations for results display
Rafal Gaweda
Message 93 of 146
mateaus
I would like to add a fiew pages in my note like the attached file by macros VBA.
caracteristics
+nodes
+bars
+loads
+ Captures of views
Message 94 of 146
Rafal.Gaweda
caracteristics
+nodes
+bars
+loads
+ Captures of views
Is that possible ?
I guess you want to make screen captures of tables.
Create table, make screen capture of it, Example code below:
Dim Rtable As RobotTable
Dim ScPar As RobotTableScreenCaptureParams
Set ScPar = robapp.CmpntFactory.Create(I_CT_TABLE_SCREEN_CAPTURE_PARAMS)
ScPar.Name = "Rtable"
Set Rtable = robapp.Project.ViewMngr.CreateTable(I_TT_BARS, I_TDT_BAR)
'  Rtable.AddColumn 1  -  modify tables if you want by adding or removing columns
Rtable.MakeScreenCapture ScPar
Rafal Gaweda
Message 95 of 146
Rafal.Gaweda
I've got a problem to export result view in a file (word or rtf)
 and the header with word are not good :
 Can you help me ?
If it is not sorted out by you please send me your macro.
Rafal Gaweda
Message 96 of 146
mateaus
My command
doesn't work any more.
Do you have a solution. I just want to save and quit the model.
Message 97 of 146
Rafal.Gaweda
robapp.Quit I_QO_SAVE_CHANGES
Rafal Gaweda
Message 98 of 146
mateaus
that's the same Robot can't close normally. The programm bug :
Message 99 of 146
Rafal.Gaweda
Send me the latest version of your macro.
Rafal Gaweda
Message 100 of 146
mateaus
Sub robot_donnees()
' ouverture de robot, la session s'appellera robapp
Set Robapp = New RobotApplication
' ce sera une structure de type panneaux
Robapp.Project.New (I_PT_SHELL)
If Range("I24").Value = "NON" Then
Robapp.Visible = False
Else
Robapp.Visible = True
End If
If Range("I25").Value = "NON" Then
Robapp.Interactive = False
Else
Robapp.Interactive = True
End If
If Range("I26").Value = "NON" Then
Robapp.UserControl = False
Else
Robapp.UserControl = True
End If
Dim RetVal
Sleep 1000
A = Range("AE2").Value
affaire = Range("AE14").Value
Robapp.Project.OpenExtFile A, I_EFF_STR, 1  ' Ouvre le fichier text se trouvant dans A
Call initialisation_semelle
Call Plaque_Robot
' MsgBox "Calcul terminé"
'robapp.Project.Close
'robapp.Quit = True
'Appuis entretoises
'Call appuis_robot
Call charges
Robapp.Project.CalcEngine.Calculate ' calculate model
'Vue mise à jour
mavueRobot.ParamsDisplay.SymbolSize = 2 'marche uniquement avec ROBOT 2012
'sauvegarde fichier robot
sauv = affaire
Robapp.Project.SaveToFormat I_PSF_RTD, sauv
'robapp.Project.SaveAs sauv
End Sub
