Discussion Groups
Robot Structural Analysis
Product Support
Rafal.Gaweda
Re: Command VBA Projection Capture of a view
12-12-2011 06:55 AM in reply to: mateaus
Try this:
mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_NODE_NUMBERS, True
mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_BAR_NUMBERS, True
RobApp.Project.ViewMngr.Refresh
Rafal Gaweda
Please use plain text.
Distinguished Contributor
mateaus
12-12-2011 08:32 AM in reply to: Rafal.Gaweda
It doesn't work
error
I would like also change the size of symbols like :
mavueRobot.ParamsDisplay.SymbolSize = 5
This command doesn't change anything.
Product Support
Rafal.Gaweda
12-12-2011 08:37 AM in reply to: mateaus
I asked you to use this syntax:
Rafal Gaweda
mateaus
12-12-2011 09:45 AM in reply to: Rafal.Gaweda
Ok sorry and for the syze of symbols ?
Active Contributor
sorgjee
12-12-2011 01:25 PM in reply to: mateaus
Re SymbolSize; is it correct that this only takes an integer, and that the symbolsize represented in Robot is ten times of this?
E.g. SymbolSize = 2 gives a symbol size in robot of 20.
Similarly SymbolSize = 1.5 gives 20, and SymbolSize = 1.4 give 10.
Product Support
Rafal.Gaweda
12-13-2011 12:48 AM in reply to: sorgjee
and that the symbolsize represented in Robot is ten times of this?E.g. SymbolSize = 2 gives a symbol size in robot of 20.
Yes it is like that. 1 in API coresponds to 10 in Robot.
Rafal Gaweda
mateaus
12-13-2011 10:16 AM in reply to: sorgjee
It doesn't work, can you send me an example ?
'mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_NODE_NUMBERS = True
'mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_BAR_NUMBERS = True
mavueRobot.ParamsDiagram.Set I_VDRT_NTM_FX, False
mavueRobot.ParamsDiagram.Set I_VDRT_NTM_FZ, False
mavueRobot.ParamsDiagram.Set I_VDRT_NTM_MY, False
'mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_OFFSETS, True
mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SHAPE, True
mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_ELASTIC_FOUNDATION, True 'afficher sol elastique
'mavueRobot.ParamsDisplay.Set I_VDA_FE_PANEL_THICKNESSES, True
'mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_COLORS, True
mavueRobot.Redraw (0)
mavueRobot.ParamsDisplay.SymbolSize = 2
robapp.Project.ViewMngr.Refresh
Product Support
Rafal.Gaweda
12-14-2011 12:59 AM in reply to: mateaus
mateaus
01-09-2012 10:59 AM in reply to: Rafal.Gaweda
I'd like to ask in the view this :
Reaction Fx
How can I make it ?
Product Support
Rafal.Gaweda
01-10-2012 02:20 AM in reply to: mateaus
Reaction Fx
Unfortunately it is not implemented in API.
Rafal Gaweda
