I have a problem with my macro. The command of projection in 3D doesn't work. My view stay in XZ plane.
robapp.Window.Activate
Set mavueRobot = robapp.Project.ViewMngr.CreateView(1)
mavueRobot.Projection = I_VP_3DXYZ
mavueRobot.Visible = True
mavueRobot.Redraw (True)
I want also make a capture of my model with diagram of results. Have you an example of code for it ?
I would like to get for final result the exemple in attachment.
Solved by Rafal.Gaweda. Go to Solution.
Maybe you can find the solution in my VBA codes.
I send you the file text of the model.
The case 1 and 2 are defined in the text file. The case 3 is defined in VBA. Do you need Excel file to verify ?
Yes, but loads assigned directly to FEs are no displayed
Please attach.
I would like to have the moment My on the view, I suppose it's a command like
mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_COMPLEX_REINFORCE_TOP_MXX
maybe
mavueRobot.ParamsFeMap.CurrentResult = I_VBMRT_NTM_MY
Sub cree_vues_resultats() Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view Set mavueRobot = robapp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use GetView instead mavueRobot.ParamsDisplay.Set I_VDA_OTHER_RULER, True mavueRobot.Visible = True mavueRobot.Redraw (True) robapp.Project.ViewMngr.Refresh ' displaying map mavueRobot.ParamsFeMap.WithDescription = True mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SYMBOLS, False mavueRobot.ParamsFeMap.CurrentResult = I_VBMRT_NTM_MY For i = 1 To 26 mavueRobot.Selection.Get(I_OT_CASE).FromText (i) ' selecting case for results display ecran_capture = "moments My - Cas " & i mavueRobot.Redraw (0) robapp.Project.ViewMngr.Refresh Call screen_capture Next i End Sub
maybe
VFMRT means ViewFEMapResultsType -> this works for mavueRobot.ParamsFeMap.CurrentResult
VBMRT means ViewBarMapResultType
so I guesss you look for :
I_VFMRT_COMPLEX_REINFORCE_TOP_MYY or
I_VFMRT_COMPLEX_REINFORCE_BOTTOM_MYY or
I_VFMRT_DETAILED_MOMENT_YY
My project is a Portique Plan with bar so I looking for My (Diagrams).
Can you correct my macro ?
Do you know the command to clean all the screen captures ?
' displaying My diagram
mavueRobot.ParamsDiagram.Set I_VDRT_NTM_MY, True
For i = 1 To robapp.Project.PrintEngine.ScreenCaptures.Count
robapp.Project.PrintEngine.ScreenCaptures.Remove robapp.Project.PrintEngine.ScreenCaptures.Get(1)
Next i
Hi this commands don't work
mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_NODE_NUMBERS = True
mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_BAR_NUMBERS = True
Try this:
mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_NODE_NUMBERS, True
mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_BAR_NUMBERS, True
RobApp.Project.ViewMngr.Refresh
I asked you to use this syntax:
Re SymbolSize; is it correct that this only takes an integer, and that the symbolsize represented in Robot is ten times of this?
E.g. SymbolSize = 2 gives a symbol size in robot of 20.
Similarly SymbolSize = 1.5 gives 20, and SymbolSize = 1.4 give 10.
and that the symbolsize represented in Robot is ten times of this?E.g. SymbolSize = 2 gives a symbol size in robot of 20.
Yes it is like that. 1 in API coresponds to 10 in Robot.
It doesn't work, can you send me an example ?
'mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_NODE_NUMBERS = True 'mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_BAR_NUMBERS = True mavueRobot.ParamsDiagram.Set I_VDRT_NTM_FX, False mavueRobot.ParamsDiagram.Set I_VDRT_NTM_FZ, False mavueRobot.ParamsDiagram.Set I_VDRT_NTM_MY, False 'mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_OFFSETS, True mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SHAPE, True mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_ELASTIC_FOUNDATION, True 'afficher sol elastique 'mavueRobot.ParamsDisplay.Set I_VDA_FE_PANEL_THICKNESSES, True 'mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_COLORS, True mavueRobot.Redraw (0) mavueRobot.ParamsDisplay.SymbolSize = 2 robapp.Project.ViewMngr.Refresh
I'd like to ask in the view this :
Unfortunately it is not implemented in API.
