(API) Command VBA Projection Capture of a view
145 REPLIES 145
Message 1 of 146
mateaus
8536 Views, 145 Replies
I have a problem with my macro. The command of projection in 3D doesn't work. My view stay in XZ plane.
robapp.Window.Activate
Set mavueRobot = robapp.Project.ViewMngr.CreateView(1)
mavueRobot.Projection = I_VP_3DXYZ
mavueRobot.Visible = True
mavueRobot.Redraw (True)
I want also make a capture of my model with diagram of results. Have you an example of code for it ?
I would like to get for final result the exemple in attachment.
145 REPLIES 145
Message 2 of 146
Artur.Kosakowski
in reply to: mateaus
Seems like one line is missing:
robapp.Project.ViewMngr.Refresh
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 146
mateaus
Ok but it's not working.
See my attachment
Message 4 of 146
Artur.Kosakowski
It seems like you missed the attachment.
Artur Kosakowski
Message 5 of 146
mateaus
in reply to: Artur.Kosakowski
Message 6 of 146
Rafal.Gaweda
Hi
Take a look at attached movie
Rafal Gaweda
Message 7 of 146
Rafal.Gaweda
Hi
It seems it is related to your computer graphics card (and maybe also 64 bit Robot).
On one of our computers I have the same bahavior.Switching between views (several times), refreshing them manualy etc refreshes view on this viewport.
Rafal Gaweda
Message 8 of 146
mateaus
in reply to: Rafal.Gaweda
The excel file has been created 5 years ago, I don't think this is a problem related to 64 bit Robot.
Message 9 of 146
Rafal.Gaweda
No, it was created 09.2001 🙂
Rafal Gaweda
Message 10 of 146
Rafal.Gaweda
Update to "your" macro to set map display on view and to make screen capture
Read comments in code below
Public Sub CreeVueRM()
' définition d'une vue
robapp.Interactive = True
robapp.Visible = True
robapp.Project.CalcEngine.Calculate ' calculate model
Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
Set mavueRobot = robapp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use GetView instead
mavueRobot.Selection.Get(I_OT_CASE).FromText ("3") ' selecting case for results display
' displaying map
mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_GLOBAL_DISPLACEMENT_Z
' making screen capture
Dim ScPar As RobotViewScreenCaptureParams
Set ScPar = robapp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
ScPar.Name = "My screen capture"
ScPar.UpdateType = I_SCUT_UPDATED_UPON_PRINTING
mavueRobot.MakeScreenCapture ScPar
robapp.Project.PrintEngine.SaveReportToOrganizer
End Sub
Rafal Gaweda
Message 11 of 146
mateaus
Ok thanks a lot,
I would like lo have only the screen capture in a file like .jpeg.
In Robot, I can only make a world file and the picture is in a bad quality.
Can we save the capture in a better quality.
I would like to make a macro saving many capture in C:Autodesk.
Is it possible ?
Message 12 of 146
Rafal.Gaweda
yes it is possible :
 to create png screen capture with highest reolution
ScPar.UpdateType = I_SCUT_CURRENT_VIEW
ScPar.Resolution = I_VSCR_4096
then you have to export printout to word or save as rtf
or copy directly screen shot to clipboard
ScPar.UpdateType = I_SCUT_COPY_TO_CLIPBOARD
then paste clipboard contents in Word
Rafal Gaweda
Message 13 of 146
mateaus
Ok but I would like the macro export herself the printout in a folder like C:Autodesk/output.
Message 14 of 146
Rafal.Gaweda
robapp.Project.PrintEngine.AddScToReport "My screen capture"
' saving printout \ report to file
robapp.Project.PrintEngine.SaveReportToFile "c:\Autodesk\output\rr.rtf", I_OFF_RTF_JPEG
'or directly opening printout in Word
robapp.Project.PrintEngine.ExternalPreviewReport EPF_MS_OFFICE
Rafal Gaweda
Message 15 of 146
mateaus
Ok thank you. There is just one command who don't work.
I didn't find it in the ROS manual V9.0.
Is there a mistake or is it no more available ?
Message 16 of 146
Rafal.Gaweda
Hi
This command is from ARSA 2012, ROS 12
Rafal Gaweda
Message 17 of 146
mateaus
I have Autodesk Robot Structural Analysis Professional 2011.
Does it work with this software ?
Message 18 of 146
Rafal.Gaweda
You already know it does not.
It is implemented in ARSA 2012, Robot Object Modeler 12
Rafal Gaweda
Message 19 of 146
mateaus
I only find the manual of ROS V9. Do you have the manual of ROS V11 ?
Message 20 of 146
Rafal.Gaweda
it should be there:
"C:\Program Files\Common Files\Autodesk Shared\Structural\Help\2011\robotom.pdf"
Rafal Gaweda
