I have a problem with my macro. The command of projection in 3D doesn't work. My view stay in XZ plane.
robapp.Window.Activate
Set mavueRobot = robapp.Project.ViewMngr.CreateView(1)
mavueRobot.Projection = I_VP_3DXYZ
mavueRobot.Visible = True
mavueRobot.Redraw (True)
I want also make a capture of my model with diagram of results. Have you an example of code for it ?
I would like to get for final result the exemple in attachment.
Solved by Rafal.Gaweda. Go to Solution.
Seems like one line is missing:
robapp.Project.ViewMngr.Refresh
Hi
It seems it is related to your computer graphics card (and maybe also 64 bit Robot).
On one of our computers I have the same bahavior.Switching between views (several times), refreshing them manualy etc refreshes view on this viewport.
The excel file has been created 5 years ago, I don't think this is a problem related to 64 bit Robot.
Update to "your" macro to set map display on view and to make screen capture
Read comments in code below
Public Sub CreeVueRM()
' définition d'une vue
robapp.Interactive = True
robapp.Visible = True
robapp.Project.CalcEngine.Calculate ' calculate model
Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
Set mavueRobot = robapp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use GetView instead
mavueRobot.Selection.Get(I_OT_CASE).FromText ("3") ' selecting case for results display
' displaying map
mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_GLOBAL_DISPLACEMENT_Z
' making screen capture
Dim ScPar As RobotViewScreenCaptureParams
Set ScPar = robapp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
ScPar.Name = "My screen capture"
ScPar.UpdateType = I_SCUT_UPDATED_UPON_PRINTING
mavueRobot.MakeScreenCapture ScPar
robapp.Project.PrintEngine.SaveReportToOrganizer
End Sub
Ok thanks a lot,
I would like lo have only the screen capture in a file like .jpeg.
In Robot, I can only make a world file and the picture is in a bad quality.
Can we save the capture in a better quality.
I would like to make a macro saving many capture in C:Autodesk.
Is it possible ?
yes it is possible :
to create png screen capture with highest reolution
ScPar.UpdateType = I_SCUT_CURRENT_VIEW
ScPar.Resolution = I_VSCR_4096
then you have to export printout to word or save as rtf
or copy directly screen shot to clipboard
ScPar.UpdateType = I_SCUT_COPY_TO_CLIPBOARD
then paste clipboard contents in Word
Ok but I would like the macro export herself the printout in a folder like C:Autodesk/output.
robapp.Project.PrintEngine.AddScToReport "My screen capture"
' saving printout \ report to file
robapp.Project.PrintEngine.SaveReportToFile "c:\Autodesk\output\rr.rtf", I_OFF_RTF_JPEG
'or directly opening printout in Word
robapp.Project.PrintEngine.ExternalPreviewReport EPF_MS_OFFICE
Ok thank you. There is just one command who don't work.
I didn't find it in the ROS manual V9.0.
Is there a mistake or is it no more available ?
I have Autodesk Robot Structural Analysis Professional 2011.
Does it work with this software ?
You already know it does not.
It is implemented in ARSA 2012, Robot Object Modeler 12
it should be there:
"C:\Program Files\Common Files\Autodesk Shared\Structural\Help\2011\robotom.pdf"
