Discussion Groups
Robot Structural Analysis
Distinguished Contributor
0 Kudos
Command VBA Projection Capture of a view
970 Views, 104 Replies
10-12-2011 02:50 AM
I have a problem with my macro. The command of projection in 3D doesn't work. My view stay in XZ plane.
robapp.Window.Activate
Set mavueRobot = robapp.Project.ViewMngr.CreateView(1)
mavueRobot.Projection = I_VP_3DXYZ
mavueRobot.Visible = True
mavueRobot.Redraw (True)
I want also make a capture of my model with diagram of results. Have you an example of code for it ?
I would like to get for final result the exemple in attachment.
Product Support
760 Kudos
Re: Command VBA Projection Capture of a view
10-12-2011 03:31 AM in reply to: mateaus
Seems like one line is missing:
robapp.Project.ViewMngr.Refresh
Artur Kosakowski
0 Kudos
10-12-2011 10:22 AM in reply to: mateaus
Ok but it's not working.
See my attachment
Product Support
760 Kudos
10-13-2011 12:01 AM in reply to: mateaus
It seems like you missed the attachment.
Artur Kosakowski
0 Kudos
10-13-2011 01:01 AM in reply to: Artur.Kosakowski
Product Support
1,305 Kudos
10-13-2011 01:08 AM in reply to: mateaus
Hi
Take a look at attached movie
Rafal Gaweda
Product Support
1,305 Kudos
10-13-2011 01:20 AM in reply to: mateaus
Hi
It seems it is related to your computer graphics card (and maybe also 64 bit Robot).
On one of our computers I have the same bahavior.Switching between views (several times), refreshing them manualy etc refreshes view on this viewport.
Rafal Gaweda
0 Kudos
10-13-2011 02:24 AM in reply to: Rafal.Gaweda
The excel file has been created 5 years ago, I don't think this is a problem related to 64 bit Robot.
Product Support
1,305 Kudos
10-13-2011 02:28 AM in reply to: mateaus
No, it was created 09.2001 :-)
Rafal Gaweda
Product Support
1,305 Kudos
10-13-2011 05:59 AM in reply to: Rafal.Gaweda
Update to "your" macro to set map display on view and to make screen capture
Read comments in code below
Public Sub CreeVueRM()
' définition d'une vue
robapp.Interactive = True
robapp.Visible = True
robapp.Project.CalcEngine.Calculate ' calculate model
Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
Set mavueRobot = robapp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use GetView instead
mavueRobot.Selection.Get(I_OT_CASE).FromText ("3") ' selecting case for results display
' displaying map
mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_GLOBAL_DISPLACEMENT_Z
' making screen capture
Dim ScPar As RobotViewScreenCaptureParams
Set ScPar = robapp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
ScPar.Name = "My screen capture"
ScPar.UpdateType = I_SCUT_UPDATED_UPON_PRINTING
mavueRobot.MakeScreenCapture ScPar
End Sub
Rafal Gaweda
