Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
combining the results
2 REPLIES 2
cn10kmp
345 Views, 2 Replies
I recently had to calculate maximum moment for different load combinations (entire beam and alternative spans) to find the worst case. Is there any way of combining the results into one diagram? Ideally, I need a graph which will show 39.31(first photo) at the first span and 42.36 at the support(second phot). Is there a smart way of doing this?
Many thanks,
Kasia
2 REPLIES 2
Artur.Kosakowski
in reply to: cn10kmp
To create the graphical display of results (envelope) for many load cases select them (type their numbers) in the load case selection field (the one where you have case 3 selected on your screen capture). You can also select the predefined Combinations filter.
Artur Kosakowski
cn10kmp
in reply to: Artur.Kosakowski
Thank you!
