I recently had to calculate maximum moment for different load combinations (entire beam and alternative spans) to find the worst case. Is there any way of combining the results into one diagram? Ideally, I need a graph which will show 39.31(first photo) at the first span and 42.36 at the support(second phot). Is there a smart way of doing this?
Many thanks,
Kasia
Solved by Artur.Kosakowski. Go to Solution.
To create the graphical display of results (envelope) for many load cases select them (type their numbers) in the load case selection field (the one where you have case 3 selected on your screen capture). You can also select the predefined Combinations filter.
