Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Combining robot files
5 REPLIES 5
pevelor
1125 Views, 5 Replies
Hi
The project I am working on consists of several buildings with one shared parking garage.
The top buildings and the parking garage is split into seperate robot files.
For load take down etc I want to combine the models again into one Robot file.
Is this possible, and if so how is this done?
In addition, the above is also seperate Revit files. Is it possible to send from Revit to Robot even the linked files or how is the workflow for this?
Kind Regards
Peder
Tags (2)
5 REPLIES 5
Artur.Kosakowski
in reply to: pevelor
The top buildings and the parking garage is split into separate robot files.
Open one of the models and use
and indicate the model (file) you want to merge.
In addition, the above is also separate Revit files. Is it possible to send from Revit to Robot even the linked files or how is the workflow for this?
You can create separate rtd files for each Revit models and use the above illustrated approach.
Artur Kosakowski
O.Maille
Is there a way where the file only contains manual connections with manual loads (ie. no bars or nodes)
@pevelor wrote:
Hi
Kind Regards
Peder
Artur.Kosakowski
in reply to: O.Maille
Hi @O.Maille
Yes, you can start a new project selection the connection module stand alone and define both connections and set of forces for each of them
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
O.Maille
in reply to: Artur.Kosakowski
That's what we have done but there's now 3/4 of these files and I want them to combine into one, the above method doesn't seem to work as there is no geometry.
Artur.Kosakowski
Hi @O.Maille
I can't think of any option that would allow for merging such files Smiley Sad
Artur Kosakowski
