Discussion Groups
Robot Structural Analysis
Distinguished Contributor
pevelor
Combining robot files
203 Views, 1 Replies
08-14-2012 12:53 AM
Hi
The project I am working on consists of several buildings with one shared parking garage.
The top buildings and the parking garage is split into seperate robot files.
For load take down etc I want to combine the models again into one Robot file.
Is this possible, and if so how is this done?
In addition, the above is also seperate Revit files. Is it possible to send from Revit to Robot even the linked files or how is the workflow for this?
Kind Regards
Peder
Please use plain text.
Product Support
Artur.Kosakowski
Re: Combining robot files
08-14-2012 01:18 AM in reply to: pevelor
The top buildings and the parking garage is split into separate robot files.
Open one of the models and use
and indicate the model (file) you want to merge.
In addition, the above is also separate Revit files. Is it possible to send from Revit to Robot even the linked files or how is the workflow for this?
You can create separate rtd files for each Revit models and use the above illustrated approach.
Artur Kosakowski
