Hi!
I want to delete a node and combine two bars for a single. How I can do?
Solved by Artur.Kosakowski. Go to Solution.
Open Bars table on the edit tab and replace origin/end node numbers of bars 9 and 10 (change from 13 to e.g. 2 for bar 9). The same can be don in the Inspector after selecting one of these bars. Mind to delete the 'excessive bar first.
Do you understand that the procedure you described is not combining/merging two bars. please add this function.
