Combine two bars
5 REPLIES 5
mikibierzo1973
2828 Views, 5 Replies
Combine two bars
Hi!
I want to delete a node and combine two bars for a single. How I can do?
5 REPLIES 5
Open Bars table on the edit tab and replace origin/end node numbers of bars 9 and 10 (change from 13 to e.g. 2 for bar 9). The same can be don in the Inspector after selecting one of these bars. Mind to delete the 'excessive bar first.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
abudayev
in reply to: Artur.Kosakowski
Do you understand that the procedure you described is not combining/merging two bars. please add this function.
Rafal.Gaweda
in reply to: abudayev
abudayev
in reply to: Rafal.Gaweda
thank you!
