Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Combinations....
1 REPLY 1
andrea_pontiggia
361 Views, 1 Reply
Combinations....
I made a mistake too many combinations. I can not with the usual methods to delete the combinations created. I tried to save the file as a text file in order to delete the combinations manually. The text file has a syntax error, but I do not understand, I just deleted the combinations. Do you have any suggestions?
Andrea
1 REPLY 1
Are they combinations or code combinations? How did you create them - using the wizard?
Anyway one of these ways should be applicable:
type the number of the first combination and the last one with to key word (to is for English interface)
or run the wizard
Artur Kosakowski
