Discussion Groups
Robot Structural Analysis
andrea.pontiggia
Combinations....
178 Views, 1 Replies
01-19-2013 12:24 AM
I made a mistake too many combinations. I can not with the usual methods to delete the combinations created. I tried to save the file as a text file in order to delete the combinations manually. The text file has a syntax error, but I do not understand, I just deleted the combinations. Do you have any suggestions?
Andrea
Please use plain text.
Product Support
Artur.Kosakowski
Re: Combinations....
01-21-2013 12:39 AM in reply to: andrea.pontiggia
Are they combinations or code combinations? How did you create them - using the wizard?
Anyway one of these ways should be applicable:
type the number of the first combination and the last one with to key word (to is for English interface)
or run the wizard
Artur Kosakowski
