I have a question about different SLS combinations. (for example for support reaction node 1539 ).
I created automatic combinations.
As results, I am expecting to get :
SLS- minimum value from automatic combinations
SLS+ max value from automatic combinations
SLS - I am not sure but it would be logical to have both values (SLS- and SLS+) (Please correct me if I am wrong)
However, when I am looking at reactions (diagrams) ,
SLS+ and SLS- are the same and show both values,
SLS shows value which is not max and not min.
Can anybody advise what is the explanation for such SLS?
regards,
kris
Solved by Rafal.Gaweda. Go to Solution.
Lokk here:
For Bars diagram top and bottom envelopes are displayed toghether always.
SLS \ ULS \ ACC - without sign - results presentation for each generated combination:
By the way I have another quick question: Is there any way for reactions to change labels orientation or size of fonts?
It is sometimes difficult to read printouts.
Drag labels to different locations.
Orientation - not posssible to change
Size - the easiest way : PageUp PageDown keys on keyboard
MOvie: http://screencast.com/t/26aHN4y8
