Discussion Groups
Robot Structural Analysis
New Member
NMBS
Combinations Robot
185 Views, 3 Replies
05-16-2012 02:59 AM
Hello there,
When I wish to create a simple load combination automatically. For example DL1 and LL1. And I use as safety the numbers 1.35 and 1.50 respectively. Robot refuses tot generate the combination: 1.35xDL1 + 1.50xLL1 but instead gives me: 1.35xDL1 + 0.7x1.50xLL1. I have tried changing the factor 0.7 to 1.0 but it had no effect. As I see it, Robot uses the combination factor (0.7) to fast.
It is a simple question that keeps me guessing. I suppose there is a simple sollution that I just fail to see...
Best regards,
Tim
Please use plain text.
Product Support
Rafal.Gaweda
Re: Combinations Robot
05-16-2012 03:05 AM in reply to: NMBS
I assume we are talking about code combinations.
Which code do you use?
Rafal Gaweda
New Member
NMBS
05-21-2012 12:37 AM in reply to: Rafal.Gaweda
Your assuption is correct. I am talking a
I have tried : NBN EN 1990-ANB: 2007
                     EN 1990: 2002
                     EUROCDE BELGIUM
But I seem to have the same problem with all 3.
Best regards
Product Support
Rafal.Gaweda
05-21-2012 06:34 AM in reply to: NMBS
I depends on ksi0,1 value:
For EN code use CAT E live loads
Rafal Gaweda
