I have 3 wind load cases Fx, Fy, Mz plus load cases for gravity loads (Dead, live....) . I need to create 24 wind load combinations, for example:
Wcomb1 = Fx+0.75Fy+0.35Mz
or
Wcomb2 = 0.5Fx+0.5Fy ..... etc.
up to Wcomb24
Then I need to generate load combinations according to the code, for example:
1.2D+1.6L+1.4W or 0.9D+1.6W and so on..., where instead of W I need to substitute each of 24 wind load combinations.
In the end it turns out to be more than 250 combinations.
What is the best way to generate these combinations in Robot? As far as I understand I will need to create wind load combinations by hand, but I'm not sure how to generate code combinations with each of these 24 Wcomb. I've read the manual, but still confused about how to do this. I don't have experience with creating load combinations in Robot and I'm especially confused with relations, so detailed answer will help a lot.
Thank you.
Solved by Artur.Kosakowski. Go to Solution.
Try the following:
1. Define 24 dummy wind load cases W1, W2 ... W24.
2. Generate manual combinations using the combination wizard (1.2D+1.6L+1.4W or 0.9D+1.6W and so on...)
3. Create additional 24 combinations (Wcomb1 = Fx+0.75Fy+0.35Mz or Wcomb2 = 0.5Fx+0.5Fy ..... etc.)
4. Edit the combinations from the point 1 replacing W1 with Wcomb1, W2 with Wcomb2 etc.). This can be done either in Robot or in Excel.
