What is the difference between "Combination Type" and "Case nature"?
How are they connected with the design code of steel or concrete?
thanks
Solved by Artur.Kosakowski. Go to Solution.
Combination type is according to the selected 'load combination' code. The case nature is to determine the default load factor if you want to create a new load combinations with already existing combinations as its components.
