Combination problem
5 REPLIES 5
andrea_pontiggia
360 Views, 5 Replies
Combination problem
I do not understand why the combinations are truncated with "......". (See image)
How can I see them entirely?
Another question.
If you use the "automatic simplified combinations", the generated combinations are not shown in the table. you can make them visible to be modified, as in the following image?
Andrea
5 REPLIES 5
How long are these definitions? Try to make this field longer or increase its height.
The simplified code combinations are generated after calculations of the model. Then they should be displayed in the combination table. Their edition can be done when you convert them into the manual one.
Mind that you have to switch the display of the table from manual combinations to automatic combinations if both types exist in the model.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
"How long are these definitions? Try to make this field longer or increase its height."
I increased the width of the columns and the height but nothing changes. Is truncated to the last term.
"The simplified code combinations are generated after calculations of the model. Then they Should Be Displayed in the combination table". OK
"Their edition can be done when you finish convert them into the manual one."
How can i do?
"Mind That You have to switch the display of the table from manual to automatic combinations combinations if Both types exist in the model."
I did not understand
Andrea
See the attached picture.
Artur Kosakowski
Sorry, I have another question. I did what you told me.
The generated combinations are not divided into SLS-CHR, SLS-QPR, etc., but they are only generic SLS.
Why is that?
tanks
Andrea
This depends on the regulation file(s) you used.
Artur Kosakowski
