I do not understand why the combinations are truncated with "......". (See image)
How can I see them entirely?
Another question.
If you use the "automatic simplified combinations", the generated combinations are not shown in the table. you can make them visible to be modified, as in the following image?
Solved by Artur.Kosakowski. Go to Solution.
How long are these definitions? Try to make this field longer or increase its height.
The simplified code combinations are generated after calculations of the model. Then they should be displayed in the combination table. Their edition can be done when you convert them into the manual one.
Mind that you have to switch the display of the table from manual combinations to automatic combinations if both types exist in the model.
"How long are these definitions? Try to make this field longer or increase its height."
I increased the width of the columns and the height but nothing changes. Is truncated to the last term.
"The simplified code combinations are generated after calculations of the model. Then they Should Be Displayed in the combination table". OK
"Their edition can be done when you finish convert them into the manual one."
How can i do?
"Mind That You have to switch the display of the table from manual to automatic combinations combinations if Both types exist in the model."
I did not understand
See the attached picture.
Sorry, I have another question. I did what you told me.
The generated combinations are not divided into SLS-CHR, SLS-QPR, etc., but they are only generic SLS.
Why is that?
tanks
