Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Columns calculation
10 REPLIES 10
Message 1 of 11
faisal.aaouatif
621 Views, 10 Replies
Columns calculation
would the message in the attachement mean that the calculations with bending are concidered or not ( regarding the the ligne just above )
10 REPLIES 10
Message 2 of 11
This means that bending has not been take into account for fire resistance calculations.
Artur Kosakowski
Message 3 of 11
Ist there any reason for that or is it a limitation to the current version of the software ?
Is all the warnings appearing between two message numbers are only relative to the firt one ?
thank you
Message 4 of 11
What is the design code you selected?
Could you send me this example?
Artur Kosakowski
Message 5 of 11
Calculation option  BAEL91 mod99 Regulation BAEL91RPS2000.
having a a problem with my model : connot generate ULS and SLS combinations ( only ACC are generated ! ).
thanks for support
Message 6 of 11
Send me the rtd file please.
Artur Kosakowski
Message 7 of 11
ok , not managed to upload to autocad360 , please find a link blelow :
http://wtrns.fr/pnjYq_8Zq2Vdmr
thanks
Message 8 of 11
You have to define relations among load cases (see the attached picture)
Which RC column shall I look at?
Artur Kosakowski
Message 9 of 11
Exporting the column 727 for example
Message 10 of 11
The warning informs that the estimated method for fire resistance is not applicable for bending. It can only be used for compression and slenderness below 35 as stated in DTU P 92-701.
The exact method for bending is not available in Robot yet as far as I know you the freeware named CIMFEU for this kind of calculation is available from:
CIMbéton
7, Place de la Défense
92 974 Paris-La-Défense Cedex
+33 (0) 1 55 23 01 12
Artur Kosakowski
Message 11 of 11
Clear and precise.
Thank you for all
