Discussion Groups
Robot Structural Analysis
70 Kudos
Columns calculation
352 Views, 10 Replies
01-06-2013 10:34 AM
would the message in the attachement mean that the calculations with bending are concidered or not ( regarding the the ligne just above )
Product Support
760 Kudos
Re: Columns calculation
01-07-2013 12:39 AM in reply to: faisal.aaouatif
This means that bending has not been take into account for fire resistance calculations.
Artur Kosakowski
70 Kudos
01-07-2013 02:56 AM in reply to: Artur.Kosakowski
Ist there any reason for that or is it a limitation to the current version of the software ?
Is all the warnings appearing between two message numbers are only relative to the firt one ?
thank you
Product Support
760 Kudos
01-07-2013 03:03 AM in reply to: faisal.aaouatif
What is the design code you selected?
Could you send me this example?
Artur Kosakowski
70 Kudos
01-07-2013 03:19 AM in reply to: Artur.Kosakowski
Calculation option  BAEL91 mod99 Regulation BAEL91RPS2000.
having a a problem with my model : connot generate ULS and SLS combinations ( only ACC are generated ! ).
thanks for support
Product Support
760 Kudos
01-07-2013 03:50 AM in reply to: faisal.aaouatif
Send me the rtd file please.
Artur Kosakowski
70 Kudos
01-07-2013 04:08 AM in reply to: Artur.Kosakowski
ok , not managed to upload to autocad360 , please find a link blelow :
http://wtrns.fr/pnjYq_8Zq2Vdmr
thanks
Product Support
760 Kudos
01-07-2013 05:02 AM in reply to: faisal.aaouatif
You have to define relations among load cases (see the attached picture)
Which RC column shall I look at?
Artur Kosakowski
70 Kudos
01-07-2013 08:20 AM in reply to: Artur.Kosakowski
Exporting the column 727 for example
Product Support
760 Kudos
01-08-2013 01:27 AM in reply to: faisal.aaouatif
The warning informs that the estimated method for fire resistance is not applicable for bending. It can only be used for compression and slenderness below 35 as stated in DTU P 92-701.
The exact method for bending is not available in Robot yet as far as I know you the freeware named CIMFEU for this kind of calculation is available from:
CIMbéton
7, Place de la Défense
92 974 Paris-La-Défense Cedex
+33 (0) 1 55 23 01 12
Artur Kosakowski
