Hi all ;
Im on RSA2011 - SP6 and i'm traying to work with Reinforment Columns module under EC8.
After exporting a column from RSA the remarks ive found are :
1. even if my live loads are defined on categorie "F" wich means a coefficient Psi-2 = 0.6 ; loadind table on the RC module shows 0.30 which not modifiable .... ( is there a way to correct it ? ) -- please See attachement
2.By examining the calculation Note ; i've found these remarks -- please See attachements ::
2.a Problem in calculation final excentricity
2.b Very big Moment magnificient coeffient
2.c the effective creep is greater the conventional one wich i think not correct.
2.d How does RSA determine the coefficient Js ? it is done after obtaining the reinforcement ?
Ive done calculation of this columns in comparaison on a excel sheet , an i obtained more reasonable values ie : Magnificient coeff = 2.834 ; effective creap = 0.226 ; [can send snap shot inf required].
I need to be figure out these pb -- have several columns to calculate
Thank you for help
Solved by faisal.aaouatif. Go to Solution.
I have just noticed that you replaced the files in the different folder than I indicated:
Please replace the original files in C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2012\DBAccess
replaced files in the directory "C:\Program Files (x86)\Common Files\Autodesk Shared\Structural\COM\2012\DBAccess
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
sorry for the inconveniance but i couldnt find the DBacess directory in the "C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2012\" folder , so this is why i used the Program Files (x86) one ....
anyway (having no time to go further) , im trying to install rsapro2012 in a completly new machine on win7 pro 32 bits
i hope i'll get no problem ....
thanks a lot
Hi Artur
I am having the same issues as above and following the thread, I think the explanation to the issue was somehow lost in the other details. Could you please comment on that issue specifically?
Stroxy,
Please check your acting axial force vs. the critical force for this column. My assumption is that you it is either very close or above it.
7.in the formula computing the rigdity ( EJ )shown at the calculation note ; it seems that the module Ecd is not divided by (1+coeff effective creep). - Is RSA consider that the column isolated even if its a part of hyperstatic structure ? (Reminder : See Eurocode2 - Art5.8.7.2.(4)) [Priority 1]
Correct. The request for implementation of Art5.8.7.2.(4)) is added to the wish list.
Implemented in Robot 2015.
